NE South Dakota Clark, SD | I am going to guess, but I could be wrong. The field that is 7 acres long may be because you did not have your header position switch set properly set for the crop, or you did not raise the head high enough to trigger it. As far as accurate yield, did you do full calibration? Vibration, Temperature, Moisture, and full multi load calibration? Most farmers do not not take the time to do it right. You may be the exception. |
