| I can not tell you how to affect the HDOP, but you can change the SmarTrax to ignore it. Get your Raven rep to show you how you how to get the SmarTrax service mode activated (Raven's tech support may tell you how to do this on the phone, you do have a good reason to know how to do this), then change the allowable HDOP to something high enough to keep it online. At least now you can decide to steer manually if this causes skips. The bad news is you have to do this every time the SmarTrax is powered up. It will not keep the new HDOP. | |
