Posted 11/13/2018 18:37 (#7103949 - in reply to #7101532) Subject: RE: Need a PWM and encoder
ROCKHAMPTON CENTRAL QLD
I think Northern Tool is the go to there for the Brand PWM valve, you could use a proximity sensor on a sprocket for an encoder. Are you using a strip till module? I have the pinouts if you need.
