Search Forums | Classifieds (183) | Skins | Language
Pro 700 and guidance in swather
croptecsolutions
Posted 11/7/2018 19:09 (#7091452)
Subject: Pro 700 and guidance in swather
ok
I'm relatively new to guidance but I have a wd2104 windrower with pro700 nav and 372 rangepoint rtk. I cannot get this thing to drive centered to the header. I have no offsets in the system. First off the guidance lags about 3-5 seconds behind real time. This is part of the problem but the main problem is the left hand side of the header overlaps about a foot and the right hand side is about as close to exactly on the cut line as it can get. If its leaving a 2" strip it will do it the length of the field. Every pass.
I have a 16 foot disk head. Set with 15' working width. But I cannot figure out why it wont center the machine on the line.
It even shows the overlap on the display. I'll try anything if someone has an idea. TIA
