Posted 11/5/2018 12:29 (#7086303) Subject: Field IQ raven replacement on spreader
put field IQ in for raven 660 on a dry spreader with pwm valve and raven sensor on shaft to do VR. I cant seem to get the rate to work unless i got the encoder number down to 2 then seems close. Worked fine with setting the spreader constant in 660 using the 180 number. Does the field IQ need a different number? Or are you suppose to figure out the discharge factor?
