roaming | bnobles - 11/3/2018 07:16
I’ve done a circle on the Pro700 before but I think I remember that I had to stop and move over a line at the completion of each circle. I was wondering if there was a way to do a continuous spiral from a central starting spot?
Yes, it's called Spiral Swath. Once you create it, you can use it from the inside out or the outside in, but you have to create the swath either by driving once around the field from the outside, or generate it based on a boundary and implement width. |
