Search Forums | Classifieds (8) | Skins | Language
Reichhardt Tac on JD 9670
TS79
Posted 11/3/2018 06:03 (#7080993)
Subject: Reichhardt Tac on JD 9670
NE Iowa
Running a Reichhardt Tac system on our JD 9670, our machine has the silver can style flow sensor. We run an ag leader paradyme system on it for steering in beans, everything works fine then. When I switch to the reichhardt for corn the machine steers just fine but the system will kick out randomly thinking that the steering wheel is being turned.. I can adjust the manual override number higher on the reichhardt but then it doesn't disengage very well when turning the steering wheel.. I was looking back through the installation instructions from the ag leader system that I put on years ago and I see there was two spacers installed at the flow sensor for the manual override. Would these spacers on the sensor be causing my kick out issues on the reichhardt? Reichhardt was stumped when I spoke with them.. TIA
