Search Forums | Classifieds (40) | Skins | Language
pro 700 and trimble field IQ controller
raider2b
Posted 11/1/2018 06:50 (#7077217 - in reply to #7076826)
Subject: RE: pro 700 and trimble field IQ controller
North Dakota
Yup, that is a field iq rate and section control. It will connect to the 700 through the 9 pin iso harness and you will need an unlock for the 700 84601260. Cost is $795 . When used with a 700 it is called accucontrol and is set up on your screens similar to how you set up a planter. The passcode is for versions 28.5 and higher, current version is 31.XX
Bowman shows they have 2 of the unlocks on hand. Should be able to call any West Plains store to get it.
edit: additional info
Edited by raider2b 11/1/2018 06:56
