roaming | Pat H - 10/29/2018 05:19
If setup for application will any of the caseih display/controllers directly control a hydraulic remote via CAN. I have an 04 MX305 that wasn't steer ready (I installed the steering valve to work with my mojo stuff) so I'm not sure what wiring exists in the tractor. Certainly it has a canbus system since the armrest controls are connected by canbus. Thanks
No. The 600/700 will control remote settings like flow timers and percent flow, but you cannot put a remote in extend/retract/float using the display. |
