Search Forums | Classifieds (199) | Skins | Language
CIH autosteer problems
CASE3594
Posted 10/28/2018 23:53 (#7071286 - in reply to #7071248)
Subject: RE: CIH autosteer problems
Tuscola, IL
Have you tried ‘swath acquisition’ setting? It’s in the ‘NAV-P’ tab and I believe is usually set to default at 100. Usually this is too high, especially on a Magnum. But, you might try bumping it up to see if it helps with getting to the line. Too high will make it overshoot the line then it will start to weave back and forth. But it sounds like your problem is the opposite of that.
After that, there are some advanced calibrations the dealer can do with the laptop.
What is your ‘P-gain’ currently set to? I think default for a Steiger is 3 or so. May try bumping that up slightly. Too high on that and a Steiger can get violent.
Does this tractor have an autosense sensor or potentiometer in the steering cylinder?
Lastly, you can try bumping the ‘D-gain’ up.
