swenzel - 10/5/2018 10:31
Does anyone have a diagram or know what the main pinouts are for the 26 pin connection on the back of a Pro 700 / IntelliView IV display? I would like to build a benchtop / shop cable that I can use to power up displays. Goals are two fold:
(1
) power up Pro 700 / IntelliView IV
(2
) connect 252/262/372 GPS and be able to set/up configure using RDI screens.
I may even use the harness on UTV to test GPS units as well. I already have an old display cable from a sprayer that was converted to a different system. I also have plenty of 12 pin harnesses/cables to connect to 252/262/372. I just need to know the main pinouts to use on the 26 pin connector on back of display. We do have one CIH machine on the farm with pro 700 that I could reverse engineer the pins if need be
I realize Ag Express makes a cable that is already set up to do what I want as well:
https://store.agexpress.com/ProductDetails.asp?ProductCode=AE2871
