North Central MN | We have a 2011 model 9630t that has a rubbed wire somewhere in the greenstar harness. It's shorting to the 12v wire and showing 10 volts on one of the two low voltage wires, they're supposed to be 2.5v each, it works intermittently. Can find the 10 volts at the reciever plugin, therefore the messages are not being sent to the screen.
Question is, anyone know a known bad spot in this harness to look at first before we start tearing everything apart?
Also, what kind of tools do we need to take that style pin out of the connectors on the different controllers?
Our forecast looks like we have a couple weeks to try and get this figured out.
Any advice at all is greatly appreciated. | |
