Posted 9/29/2018 20:12 (#7016346 - in reply to #7015874) Subject: RE: Integra question for the CAN experts
Cedar Rapids, Iowa
If you had a short between the two data lines, that would stop everything. If you have one module that is holding the data lines at 5 volts, that will also stop any other modules from being able to transmit data. A bad module anywhere on the bus will stop all traffic.
