NE Indiana | My guess is you don't have the monitor set to auto calibrate. meaning after you type in your actual weight there should be a button that says perform calibration. You can set the monitor to automatically calibrate once you type in the actual weight. I should add that I'm not familiar with that style of calibrating I know they changed some stuff with the incommand to allow single load calibrations but I would always still recommend the 4-5 small loads at varying speeds, Especially in beans. | |
