Near Intersection of I-35 & I-90 Southern Mn. | premiertech - 9/23/2018 20:59
There is no pressure sensor input on the App rate module
Agree, the app rate module can monitor a flow meter or shaft sensor to produce rate results and/or be connected to an implement switch to start/stop coverage maps. It can also be connected with a special serial cable to third party devices such as a Raven 440 and other controllers. There is no provision for a pressure sensor input although newer 440's do have a pressure input.
It would be possible to show pressures on the screen if you used an Ag Leader Liquid Product Control Module. This would require an Auxiliary Input Module with switches or a CAN switchbox as well. This system is designed to monitor and control the application and three pressure inputs are available. |
