NW KS/ SC ID | Hey all,
Trying to get the Trimble AgGPS 132 and 21A Lightbar rigged up to spread some dry fertilizer, and it has me stumped.
Input and output to Port A are set to LBAR, and I have the whole mess hooked together with a 46441 Cable (Keypad, the 132, and the 21a)
I have a spare 21a and hooked it up, same message.
The setup came off a fertilizer truck so the antenna's port is a tick corroded, but not bad. On the 132 it will tell me elevation, and Lat. and Long. so I am assuming the Antenna is working properly?
I am trying to set it up while stationary with the engine off, system voltage 10.6 volt according to the 132. Do I need to be moving?
I am not sure what else it can be.
Any input great appreciated,
Thanks! | |
