Posted 9/12/2018 16:38 (#6984543 - in reply to #6984483) Subject: RE: How to test a pressure transducer
ROCKHAMPTON CENTRAL QLD
If it’s 0-5v output it should be easy enough to connect power to it and put a multimeter on the output pin. (Set it to mV scale) Just blowing into it with your mouth will show a reading on the meter. You would need an adjustable air supply with a gauge to test if its accurate.
