Search Forums | Classifieds (2) | Skins | Language
Agleader sure drive
jd8560
Posted 9/9/2018 21:21 (#6979604 - in reply to #6977758)
Subject: RE: Agleader sure drive
Pipestone MN
JellyJugz - 9/8/2018 20:39
I will be using them for the 3rd season this coming spring. Only issue was I had one drive go out this spring. I'm pretty sure I dropped it from about 6'.....they replaced it under warranty. Dealer let me use his so I could start planting.
Very happy with it. I would say the only negative is u can't build on it like the Vdrive(I think multi hybrid would pay in my operation).
I am thinking about doing agleaders hydraulic down-force this winter. Its SIGNIFICANTLY cheaper than PP.
edit- they actually fixed it under warranty, the encoder went out.
It’s only cheaper if you already have the SureDrive. If you had the vDrive on it right now it would cost about the same to add it.
I sell both.
