Search Forums | Classifieds (40) | Skins | Language
Trimble GFX 750 field IQ ?
TruAcre
Posted 9/13/2018 08:39 (#6985793 - in reply to #6978790)
Subject: RE: Trimble GFX 750 field IQ ?
According to a manual I found, the GFX can do more than just spraying. These are the limitations of the GFX:
The following features are supported by Field-IQ:
l Section Control up to 24 sections including up to two fence rows
l Rate Control of one liquid material.
l Prescriptions supported with 96553-07 unlock.
l Two pressure sensors (Air, Liquid, Vacuum)
l External Master Switch input
l One lift switch
Field-IQ Supported Configurations:
l 1 Rate and Section Control Module - rate and section control, max 12 sections
l 1 Rate and Section Control Module + 1 Section only module - rate and section control,
max 24 sections
l 1 Section only module- section control only, max 12 sections
l 2 Rate and Section Modules. Rate control of 1 drive and control of 24 sections
l Pressure Sensors, Lift Switch, External Module and Rate control valves can only be
connected to the “primary module”. When a RSCM and an SCM are attached the RSCM
will default as the primary module. If two RSCM’s are attached the user must identify
the primary module.
NOTE – No switch boxes are required for Field-IQ Basic operation. Switch boxes should not be
connected during Field-IQ Basic operation.
Edited by TruAcre 9/13/2018 08:40
