Central IA | Congadulations on the DTS10! Well very different from your STS I do enjoy the simplicity on the classic DTS. An E-pro is a good choice to add simple gundnce, mapping and section control to your machine. Well an E-Pro won’t get you quite all the features of the viper 4 it will provide a good start. To begin with you will need an adaptor cable to go from the 460 harnessing to the E-pro, a single product node, and a boom speed node just to spray. Note a generic raven 460 replacement kit won’t work, you will need the Hagie specific one. For section control you’ll need an accuboom node and I believe two harnesses for section control.
I’m half a country from home at the moment but send me an email and I’ll put together a list of part numbers to make sure you get the right cables and such. | |
