North of London | No pics available but I used a tractor rim and welded short piped on the side several locations around it to allow options depending on wind and smoke.
Drop a rod about 3/4 -7/8 diameter and have a couple grates welded up with handle and a hole a fraction larger than rod so the grate will stay at whatever height is required and will spin around to be above fire or close enough to take food off easy.
Not fancy but 'free' material and it works. | |
