NE N. Dak. | There is a afs 100 antenna on this combine and I can not find a 9pin connector anywhere. Is it under the cab roof? Or does it not have one and the antenna cable is CNN 87402644 that is in front of fuse panel.
If there is no 9 pin cable between antenna and the flat 5 by fuse panel where could I find pin out of flat 5? Would like to see if there is power to antenna. Then if I can't get afs 100 antenna working into UD+ I would like to try get fmx signal into it. Which I think is done through the flat 5 connector.
I'm assuming it is factory installed yield monitor or at least factory specs.
Thanks again
