Posted 7/24/2018 02:46 (#6888844 - in reply to #6887815) Subject: RE: Mps up and down for security viewing
Yorkshire UK
I would've though 1mb up should be ample if that's what you mean. You might be able to reduce the frame rate even as low as 1fps which will reduce the bandwidth needed, also resolution could be dropped most likely.
