Search Forums | Classifieds (55) | Skins | Language
Can bus plug for field view in a 9350 case?
CASE3594
Posted 6/29/2018 23:52 (#6841929 - in reply to #6841743)
Subject: RE: Can bus plug for field view in a 9350 case?
Tuscola, IL
Not 100% sure if the field view will work on it, but the universal harness will have the diagnostic connector built in. This is the connector that is mounted in the cab on newer tractors that the puck plugs into.
As far as steering, if you are already using a Pro 700 for the planter, go with electristeer. It will run through the Pro display so all you will need is the electristeer system and a 262/372 or accustar receiver. The electristeer works great and is essentially the same system (other than display) as the Agleader ontrac. I’ve sold several ontracs and a few electristeers and everyone is happy. I have run the ontrac in our tillage tractor the past 2 years and I couldn’t be happier with how it worked. Planter tractor will have one next spring.
