| Try running the Windows Update Troubleshooter this utility is designed in way to fix Windows update errors and other issues related to it. if this works for you then well and good but if not then try to start the computer in safe mode and uninstall the update or change the windows update settings.
• Windows key + r > services.msc
• Find Windows Update on the list
• Double tap on it > Select deactivate
Or else scan your system with the Windows Repair Tool, to fix Windows issues and errors. - https://www.fixwindowserrors.biz/blog/download-windows-error-repair-...
