| Running a AgLeader geosteer system on a JD 9460RT and keep getting “error 58 steer command timeout” on the AL display when I try to engage auto steer. I have unselected all the green star options on the tractor display and today I got it to work for about 30 minutes and then it had the same error, not sure if it was coincidental or if I’m getting somewhere. I’m going to change the ISOBUS implement plug on the rear of the tractor tomorrow as I’ve seen those go bad and cause CAN issues. Anyone else have this issue? | |
