Posted 6/28/2018 20:31 (#6839794 - in reply to #6832946) Subject: RE: Painting screen on 2630
Kansas
Do what both posts suggested. The Sloan link is a very good, simple explanation of what to do. It is necessary that you do the pages in the COM PORT button. Once it is set up you should be good for the season. The reason I know is that I had to figure it out for myself this Spring. Good Luck, you will like it. You can also document what you are spraying under DOCUMENTATION.
