Search Forums | Classifieds (185) | Skins | Language
Viper Pro, turning Can Node alarms off?
Amc4life
Posted 6/13/2018 10:04 (#6810220 - in reply to #6810114)
Subject: RE: Viper Pro, turning Can Node alarms off?
Butterfield, MN
Do you have version 3.10.4.25 installed? If you do, you can go to Menu-Setup-Local-Units and put a check mark in the Shift Data Display section, which will put the box up at the top of the screen when this happens, and will not cover your coverage on the screen. If you don't have this version installed, you will not have this option available.
