Posted 6/12/2018 21:30 (#6809493 - in reply to #6809330) Subject: RE: 8410T clutch/transmission problem
Central iowa
Back side of transmission..take off bottom cover and look up. Its somewhat tricky the first time.. Vertically should have been a spring.. I have a pry bar with a pin welded for just that spring.. I normally start spring on clutch arm( left) and pry to right..
