South Central North Dakota | I got my FM 750 back in the tractor and hooked it to the planter to make sure every thing works before I store the planter. I was going thru the calibrations and can get the left and right drive calibration done , but when I try to do the actual seed flow calibration, it won't let me do the prime process then won't go thru the cycle to meter seed to count. I get an error message that a fatal flaw has occurred and the calibration wizard has shut down. We had a loaner FM1000 to plant beans with and it worked fine.Is there some thing in the software that needs to be updated or enabled?
Thanks for any help. |
