Pontiac, IL. | When you say you changed the radiator out, are you referring to the water radiator, or the oil cooler radiator? I have a 7810 PS, and when we used to pull a pull-type sprayer with a hydraulic water pump on sprayer, the hydraulic oil would get the oil AND the radiator hot if BOTH coolers/radiators were not kept CLEAN. Air and/or hot water from a hose is best to keep radiator/cooler clean. Another thought: If you changed the water radiator, did you replace with a Genuine John Deere, or an aftermarket radiator. I know of several cases where an aftermarket radiator would NOT cool like an OEM. This is on ANY color/brand of tractor. ( I just replaced a radiator on our utility tractor with an aftermarket radiator. Less than half price. However, there is ALSO LESS than half the cores in the radiator) I HOPE, since tractor does not get used hard, we will not have heating issues. | |
