Near Intersection of I-35 & I-90 Southern Mn. | You need everything you have but also need a Liquid Product Control Module since the Strip-till Module will not work for the sprayer. The Liquid Product Control module will connect to the Raven flow meter, control valve and section valves. It is generally mounted on the sprayer itself and left there. It could be mounted inside the tractor but this causes cab clutter.
I have this arrangement for both a sprayer and also spray on the planter so I have two Liquid modules but could get by with just one if I moved it. |
