southern tip Illinois | Bought this used about 2 weeks ago. It has AIM command, seven section boom, Pro 700 and Acuboom. The first thing I noticed was #3 & #5 boom valves would not shut off but when you turn the switch off or cross the headland the 3&5 went off. Now #3 stays on, it has power on both sides of the valve and cannot be shut off. When I unplug #3 it operates correctly. Also the AIM command does not work in automatic but does work in manual. In automatic the pressure slowly keeps increasing. Can anyone help? |
