Search Forums | Classifieds (136) | Skins | Language
CFX 7250 direction indicator
daves
Posted 5/14/2018 09:21 (#6759714)
Subject: CFX 7250 direction indicator
EC NE
Is there someone out there that needs to run autosteer in reverse? I'm at a loss as to why the receiver needs a direction indicator. All it does for me is cause confusion with the system. With running Ezsteer or EzPilot, when there is a problem with it engaging, it is usually caused by the direction indicator facing backwards. Does autopilot actually engage in reverse? When would you need that? Was told one time that later versions of firmware made this option controllable and you could shut the reverse feature off. Is this true? Can someone elaborate on this issue.
