Search Forums | Classifieds (1) | Skins | Language
Activating row clutches on Case 1250
1466driver
Posted 5/13/2018 10:31 (#6758125 - in reply to #6757845)
Subject: RE: Activating row clutches on Case 1250
Interstate 35 North ia
Every morning when you start go to the wizard page and make certain every thing is checked green , you can also leave boundry control off if you don't have boundrys set up on your fields , once you start planting everything is recorded and row clutches should work once you hit planted areas .
