Posted 5/10/2018 22:13 (#6754224 - in reply to #6753450) Subject: RE: GreenStar Rate Controller will not work with Section Control enabled
Sound like You need to speed up the hyd flow to the pump. If You want 40 PSI while spraying, You need to have probably 60 PSI while the boom valves are closed.
Just open the boom valves, and speed up the hyd flow until the desired PSI is achieved.
Here is a basic design. From pump to a tee, with bypass valve going to tank agitation, from tee to flow meter, to boom valves, end cap with gauge.
pump----tee with bypass valve-----flow meter-------boom valves---guage----end cap.
