Posted 5/9/2018 15:21 (#6751902 - in reply to #6751796) Subject: RE: AgLeader Foam driver error on direct command for starter
West Central Iowa
I was using the black connector on the display harness for the power to the modules. I had asked a gentleman about adding the other battery direct cable and he said to just use the black on the display cable. I added ground wires to the modules but didnt help. When it happened the pump would still hum like it wouldn't shut off. Thaanks
