Posted 5/4/2018 22:50 (#6745366 - in reply to #6744791) Subject: RE: I want some input on moving to SSD using
Cedar Rapids, Iowa
Ideally you want to clone your whole drive to the new SSD. You want the programs to run from the SSD as well, they'll load a lot faster from the SSD.
If you have a substantial amount of data, then you keep an old spinning-disk drive for data storage because the cost per GB is much cheaper than SSD, but otherwise you thow one SSD in the machine and that's it.
