Posted 4/14/2018 20:35 (#6709594 - in reply to #6709530) Subject: RE: Deere guidance signal into Smarttrax
Butterfield, MN
I can't tell you which cable, but I would recommend if you do it that you shut off the internal terrain compensation in the Deere receiver or else you'll end up getting corrected twice, which is almost worse than nothing. SF1 would probably not be any better than WAAS, but if you had access to SF3, that would be pretty excellent. Make sure that GGA, VTG, and ZDA are turned on to 10 Hz.
