Search Forums | Classifieds (5) | Skins | Language
Will a RAVEN VIPER 4 work in a 3520 CIH Spreader
Amc4life
Posted 4/13/2018 17:00 (#6706778 - in reply to #6706737)
Subject: RE: Will a RAVEN VIPER 4 work in a 3520 CIH Spreader
Butterfield, MN
It depends on the type of control nodes that are installed on it. Maybe someone can tell you for sure, but if it's the larger size nodes, like an AccuBoom or SmarTrax node, you will definitely need a CaseIH branded Viper 4. If it's the smaller enclosures, I'm pretty sure that you can get by with a regular Viper 4, but you won't be able to get the special Flex Air widgets on the screen. Which monitor is in the cab now?
