| I am from SW MN. I have the geosteer with an Integra display . In the winter months I use WASS when im spreading manure and I do have that from time to time. Usually around the same time of day. That tells me that it's a satellite issue. The display may not have enough signal from one satellite to center itself. When I am planting and spraying in the spring/summer I use the RTK from the local cell towers and I have only lost signal 3 times in 5 years. Otherwise it's as straight and the field will allow. One other thing I do when I plant is I hit the diff. Lock in case I do loose signal. That should help keep straight.
If anyone has a different suggestion. I like to hear it. Thanks | |
