North Central Ohio | No, not thru the Nav. Find the steering valve. If it is factory installed, this may not be an option. They usually have 2 blue electric coils on them. If there is a button on each end, pushing that button will turn the wheels. Push one way, then the other...go back and forth. If there is no button, there will be a small hole. I like to use a small allen wrench. Push that in the hole and the wheels will turn. Go back and forth again to free it up. Sometimes it takes quite a bit of pressure to make them go. Make sure everyone is clear of the wheels when it turns! | |
