Posted 4/11/2018 10:16 (#6702644) Subject: 1720 Maxemerge Plus
Mississippi Delta
I’ve got a 1720 with hyd drives that runs from a brown box. I took the lift assist wheels off, which had a 3 wire height potentiometer on it, and need to put a 2 wire row unit button switch. Problem is I can’t get the brown box to recognize the switch when it’s plugged in. I’m assuming I have it wired correctly. What am I doing wrong?
