East Central, Nebraska | so you already have an incommand and the whole setup is still more then a whole raven system?
find some used parts. direct command $450, liquid product module $500, some wiring $200?, all the rest of the components would be the same as the raven system you looked at. flow meter, valve, shut offs...... not sure what you were pricing for a raven system but this would give absolute control to the incommand.
i myself took the cheaper route. i bought a cheap adjustable electric pump for a few hundred dollars and an agleader app control module and a flow meter. i have no control over the product like one might with a liquid product control module and valve but i can record and see the actual rate on the monitor and adjust manually to my speed. not fancy at all but fairly inexpensive. | |
