NE CO | On the rate controller, usually when settings are greyed out that means your master switch is on, so not sure if that is your issues or not possibly.
Since you are using the rate controller to control the planter sections and most likely have it setup as Planter under the Implement tab, there isn't much for options to configure with this setup, so you won't have any options under the setup tab or even be able to get to it usually. The only tab you'll see if the Implement tab where you setup the width, sections, and there should be a check box there to use Seedstar or not.
Above all your wedgebox software is out of date, the latest version is 10.11, so getting that updated to start wouldn't hurt, especially since your running a 2630 as it will play nicer with it as well with the newer software. Rate controller can use an update as well but I don't think that is your issue at the moment, but when you update the wedgebox it wouldn't hurt to get it updated as well. Your dealer will need to help in getting the wedgebox updated as that style needs to be done through service advisor. | |
