NE Nebraska | Also, if your map on the 20/20 or field view look good, do a gps offset check and make sure all of your measurements are correct. Are you running rtk or waas for GPS service? If they are, there is a place under setup- systems- rowflow- swath config- calibration state. You can manually adjust the start or stop delay and even turn auto calibrate on for a while.
(A0969A54-ED88-4E52-B87A-A8C1587BA12D.jpeg)
Attachments ---------------- A0969A54-ED88-4E52-B87A-A8C1587BA12D.jpeg (109KB - 36 downloads)
