Butterfield, MN | The older SmarTrax or SmartSteer nodes can be used with SmarTrax MD. The software just needs to be updated to be compatible, which can be done right through the Cruizer II. The upgrade kit that was mentioned would be the perfect thing to let you use as much as you have and make it work with your Cruizer II. There will likely need to be some extra cabling to make this work, unless you already have Gen II style cabling for your current system. It's possible, but not terribly common. | |
