| A client is running a 8104 Terragator Airmax 1000 with the Falcon II controller. It is unlocked to accept Rx files. The tif files are seen by the controller, however, the product is being applied incorrectly. We have a GS3_2630 for collecting the data for where we are applying the product and are using JD steering as well; we are sharing the signal with the Falcon and we have the rx files loaded in the GS3 to use as a background - the tif image appears to be compressed into a rectangle on the falcon II vs the true nature of the field(square). As we travel around the field east to west appears correct, however, north to south, the application is wrong as the controller thinks we haven't travelled far enough and shows us turning 90degress about 2/3 of the way down the field. I had heard the rendering of the map can be off on these units but the product gets applied properly, but that doesn't appear to be the case. I also thought the application would be relative to the gps location but that doesn't appear correct either. What are we doing wrong.
TIA
Don | |
