Hennepin, IL | It's been mentioned here before, have to try doing a search tho. IIRC you'll want the antenna mounted on the hood, not the roof. Over the front axle or farther forward. On that same note, I'd try to mount the t2 box as close to over the rear axle as possible. Any time those tractors steer, the pivot point actually kicks out the opposite way. You want to avoid that as much as possible. | |
