| Working with an Ag leader Incommand 800 with a 6500 receiver. It is also running an ontrac 3. I’m using the dual port gps cable and exporting gps to a Raven smartboom. I have not had luck getting gps to the smartboom. I’ve got my baud rate at 19,200 and 5hz into the smartboom. The old owner of the machine ran Deere and it worked just fine. Pins 2,3, and 5 are populated in the smartboom serial connection. I’ve tried hooking straight into it and also using a null modem. What’s the difference between a Deere and Ag leader? | |
